Speedometer, odometer, and cruise control not working?
2005 CADILLAC CTS
150,000 MILES • 3.6L • 6 CYL • 2WD • AUTOMATIC
DALE MCCUMONS
  • 11 POSTS
There are no check engine lights on but getting service engine soon and service stability system soon on display screen. all other gauges working. I hope it might be the speed sensor it would be easy to fix. but not getting a check engine light warning. can't afford to take it to a shop. Can you test a speed sensor? i would appreciate your help. thanks
Oct 11, 2022 at 10:45 AM
It does sounds like the transmission output sensor is not working here is the location of the sensor so you can check it out. You can test the sensor by tapping into the sensor wiring harness and setting your voltameter to millivolts, then spin both axles the same way and should observe voltage if the sensor is working. here the job is being done on an ABS wheel speeds sensor but the process is the same.
https://www.2carpros.com/articles/abs-wheel-speed-sensor-test
Check out the images (below). Please let us know what you find. We are interested to see what it is.
Oct 11, 2022 at 11:22 AM
DALE MCCUMONS
  • 11 POSTS
Thanks for the info. isn't there a speed sensor on the right rear of transmission? If so, could that be the problem? really didn't want to pull pan. It said with 7 in vin is that the eighth digit. Also, what about the filter, do i need to replace? haven't had any problems with trans. Thanks for your help. It is appreciated. I'll be waiting for response. have a good day.
Oct 11, 2022 at 2:52 PM
DALE MCCUMONS
  • 11 POSTS
Hi Ken, this is Dale, thanks for the info. i sent a second set of questions i know you're busy but if you get a chance to take a look it would really help me out. Thank you very much i really appreciate it.
Oct 12, 2022 at 2:18 PM
It does look like the sensor is inside the transmission pan. I would do a filter as well and make a transmission service out of it.
Here is a guide that can help:
Oct 13, 2022 at 1:58 PM
DALE MCCUMONS
  • 11 POSTS
Hi Ken, thanks again, but what i really need to know is will the seed sensor on right side rear of the transmission fix my problem with speedometer, odometer, and cruise control?
Oct 13, 2022 at 3:00 PM
DALE MCCUMONS
  • 11 POSTS
Hi Ken, thanks for the info but can you please tell me if the speed sensor at right rear of transmission will (fix) the speedometer, odometer, and cruise instead of pulling the pan on transmission? The check engine light is not on, the car runs okay, the transmission works okay. had it hooked to code reader shows no codes. Please help as soon as possible. thank you very much.
Oct 14, 2022 at 8:45 AM
If the problem is not the sensor which without a code, it might not be or the PCM is bad. If it was a circuit error, you would have a code for that as well. Let's try a CAN scan to see if anything comes up, you can get a CAN scanner (Controller Area Network) from Amazon for about $36.00.
Here is a video to show you how:
https://youtu.be/u-4syLc-ifQ
and
https://www.2carpros.com/articles/can-scan-controller-area-network-easy
Amazon CAN scanner link for about $36.00.
https://amzn.to/3R9lJ60
Oct 15, 2022 at 12:02 PM
