Odometer not working
1990 PLYMOUTH ACCLAIM
90,000 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
JAMCO26
speedometer okay, odometer not working. I cannot find any interchange info on the speedometer only. I also have a 1989 speedometer with a non working odometer. Both are physically identical.
All ads I see are for the entire gauge cluster for other years, so I don't know if the speedometers will interchange. I can't spend $60.00 for a Hollander Interchange book to see if speedometers are listed.
Thanks
Aug 18, 2020 at 10:47 PM
I just need to clarify what issue you are having. You odometer is not working on the 1990 but you have a cluster for a 1989 that the odometer is working? You said that the 1989 and 1990 both have a speedometer that is working but non working odometer.
Just let me know if this is accurate, but I suspect you have one that has a working odometer and one that does not. Is that true? Thanks
Aug 25, 2020 at 4:28 PM
