I'm going to say no to the grease issue. Have you checked the wiring to the connector? Are you certain that the sensor is fully seated? If you take a look at the attached pic, you see there are only two wires between the sensor and the PCM (power-train control module). Either there is a wiring issue, connection issue, something preventing the new sensor from creating a signal, or the PCM is failing.
The sensor is really not even read until you exceed 8 mph. So that's why it took 100 feet. At this point, the only thing that can be done at home is checking wiring, connections, and making sure the sensor is clean and fully inserted.
The next step would be to check what is called freeze frame details using a scanner that can read such info. The info can then be used to see when and possibly where the problem starts.
I wish I had an easier answer for you. I suspect it is something with a connection issue. If possible, trace the wiring back all the way to the back to the PCM. With the battery disconnected, unplug the PCM and check connection issues there as well.
Let me know if you feel this is something you feel comfortable doing. Please note that anytime the PCM is disconnected, make sure the battery is disconnected first. Once the PCM is reconnected, then you can reconnect the battery.
Mar 21, 2020 at 10:55 AM
