Hi Tony,
I assume you are talking about the vehicle speed sensor on the transmission and transfer case? If so, here is the information you will need. However, in order to monitor these with something other than a scan tool, you will need a lab-scope. These produce a square wave form and then the combination meter sends this to the ECM.
The Red Green wire coming from the sensor is the signal wire.
Let me know if you need more information. Thanks
Jul 14, 2019 at 6:13 PM
