Speakers do not work
2000 DODGE DAKOTA
165,000 MILES • V8 • 2WD • AUTOMATIC
TREVORSWINNEY
  • 7 POSTS
The door speakers worked, but I replaced the factory radio a Kenwood kdc230u and everything is hooked up but no sound in door speakers. I hooked up my subs and they work fine vocals are coming from the subs instead of the door speakers.
Sep 9, 2017 at 12:34 PM
CARADIODOC
  • 34,306 POSTS
Most likely you have the Infinity system with the remote amplifier. You either need to bypass the amp, or you have to get the twelve volt power supply to turned it on. Your replacement radio should have a "switched twelve volt" wire, usually blue, for a power antenna or remote amp. Connect that to the truck's dark green/red wire at the end of the black plug.
If you removed a CD/cassette radio, that is the highest-quality radio I have ever worked on. I sell a lot of them for upgrades at old car show swap meets.
Be aware the amp and speakers were matched to tweak the tone response for the shape of the body. The original radio put out much less bass than normal, then it was made up by the amplifier. If you use that amp with a lower-quality radio, you will need to turn the bass way down to sound normal. Unlike with GM and Ford systems, Chrysler's amplifiers never increase volume or power. They are only for tone conditioning, so you can run speakers from your new radio with or without the amplifier.
Sep 9, 2017 at 10:43 PM
TREVORSWINNEY
  • 7 POSTS
I do have the infinity system. I will try these thank you for taking time to answer my question.
Sep 9, 2017 at 10:49 PM
CARADIODOC
  • 34,306 POSTS
You are welcome. I will be here tomorrow night if you need more help. Come back to see me again!
Sep 9, 2017 at 11:10 PM
TREVORSWINNEY
  • 7 POSTS
Okay sounds good.
Sep 9, 2017 at 11:41 PM
TREVORSWINNEY
  • 7 POSTS
If it does not work hooking it up to the remote antenna or amp how could I find and bypass the amp?
Sep 9, 2017 at 11:45 PM
CARADIODOC
  • 34,306 POSTS
The amp could be under the passenger's front seat, behind the right kick panel, or behind the left trim panel behind the driver's seat. You would have to cut the eight wires going in, and splice them to the eight wires going out. I can find the wire colors if you want to go through that much work. You might also look at places like Crutchfield online, and Best Buy, to see if they offer a simple plug-in bypass harness.
Sep 9, 2017 at 11:59 PM
TREVORSWINNEY
  • 7 POSTS
Okay.
Sep 10, 2017 at 12:11 AM
TREVORSWINNEY
  • 7 POSTS
Again thanks for your time.
TREVORSWINNEY
  • 7 POSTS
Thank you so much took the antenna wire and put it with the green and red wire and it worked thank you for all the help.
Sep 10, 2017 at 4:51 PM
CARADIODOC
  • 34,306 POSTS
Happy to hear you do not have to sing to yourself. I know your friends and neighbors will appreciate that!
Sep 10, 2017 at 7:42 PM
