Most likely you have the Infinity system with the remote amplifier. You either need to bypass the amp, or you have to get the twelve volt power supply to turned it on. Your replacement radio should have a "switched twelve volt" wire, usually blue, for a power antenna or remote amp. Connect that to the truck's dark green/red wire at the end of the black plug.
If you removed a CD/cassette radio, that is the highest-quality radio I have ever worked on. I sell a lot of them for upgrades at old car show swap meets.
Be aware the amp and speakers were matched to tweak the tone response for the shape of the body. The original radio put out much less bass than normal, then it was made up by the amplifier. If you use that amp with a lower-quality radio, you will need to turn the bass way down to sound normal. Unlike with GM and Ford systems, Chrysler's amplifiers never increase volume or power. They are only for tone conditioning, so you can run speakers from your new radio with or without the amplifier.
Sep 9, 2017 at 10:43 PM
