spark plugs get wet with petrol
2005 FORD BANTAM
176,000 MILES • 1.6L • 4 CYL • FWD • MANUAL
THANDOG
Please help, my 1.6 rocam bantam spark plugs get wet with fuel is I park it for more than 30 minutes, and it takes time to start again
Sep 29, 2015 at 8:49 AM
HMAC300
  • 48,601 POSTS
we don'thave these in US, but scan for codes and check fuel pressure with a gauge we have no specs to give you on fuel pressure. it can be leaking injectors.
Sep 29, 2015 at 9:38 AM
THANDOG
It is a Ford bantam rocam engine, I have taken it to every machenic I know but the they don't know what is the problem, but the pressure is fine, how do I make sure it is indeed a leaking injector?
Sep 29, 2015 at 10:05 AM
HMAC300
  • 48,601 POSTS
you would take initial pressure reading then check to see how much it is supposed to drop after key off and if it drops faster than that spec then go to the cylinder and try a differen injector or have a pro run injector cleaner through it first. that may cure the problem.
Sep 29, 2015 at 12:50 PM
THANDOG
Thanks will try that
Sep 29, 2015 at 1:12 PM
