Would a bad spark plug prevent the vehicle from starting?
2000 CHEVROLET ASTRO
146,000 MILES
MYVANS
  • 5 POSTS
Would a bad spark plug make the van not start?
Aug 1, 2022 at 2:58 PM
SQM
  • 6,383 POSTS
Generally speaking, an engine will need spark, fuel and compression to start.
So, if the spark plugs are not producing spark, then yes, it won't start.
However, there are a number of reasons why an engine might not start. It could be the spark plugs, also it could be due to a fuel delivery issue or compression.
https://www.2carpros.com/articles/car-not-running-advanced
Is it cranking over and not starting?
Let us know a little more details of what you are experiencing.
Thank you.
Aug 1, 2022 at 7:20 PM
MYVANS
  • 5 POSTS
It cranks but dos not start.
Aug 3, 2022 at 12:40 AM
SQM
  • 6,383 POSTS
Follow that guide I provided you on the first response. It will walk you thru how to check for spark, fuel and other crank no start issues.
Let me know what you find.
Aug 3, 2022 at 8:16 AM
MYVANS
  • 5 POSTS
Okay, one more thing. The security light stays solid it blinks three times then is solid and when I try to start dashboard lights come on, but my gauges don't move anymore.
Aug 3, 2022 at 3:42 PM
SQM
  • 6,383 POSTS
If the security light flashes then the immobilizer might be triggered.
Try disconnecting the battery for a few minutes and reconnect and see if that resets the light.
https://www.2carpros.com/articles/how-to-reset-a-security-system
Aug 3, 2022 at 8:27 PM
