Spark plug problem
1999 FORD FIESTA
79,000 MILES • 1.2L • 4 CYL • MANUAL
HAYLEY RELPH
My car has become sluggish when accelerating (especially between 1000-2000 rpm), judders when idle and loses speed on hills when driving at higher speeds.
I had this problem recently and my dad changed a spark plug, but as it has happened again I have changed the whole set.
This has improved the car's performance somewhat, but the car still judders a little when idle and it makes a 'flutter' noise when accelerating through lower gears. The ride is much smoother but it now takes a couple of turns of the key in the ignition for the car to start.
Would you have an idea from this description what may be wrong and which next steps to take? I have RAC cover so can get roadside help if needs be, but if there is something I can do or a local mechanic I can take it to that would be great.
The last time this happened I used the higher performance petrol when I next topped up and it made a small difference. I also keep the oil topped up and checked all fluids last week.
Thanks for any advice you can offer!
Jan 11, 2017 at 4:41 AM
HMAC300
  • 48,601 POSTS
scan for codes and check fuel pressure with a gauge auto parts rent it, see link.
Jan 11, 2017 at 6:58 AM
RENEE L
  • 1,260 POSTS
Hello HAYLEY,
I am sending you a link that if you decide to conduct the scan yourself will be of help to you. The link features an article with written step by step instructions and pictures explaining how to do the scan yourself, also I have included a link to our YouTube channel with a how to video on code scanning.
This is applicable even if your check engine light is not on.
Most scanners are inexpensive to purchase, you can purchase one online from sites like Amazon.com
https://youtu.be/YV3TRZwer8k
Once you have the codes please get back to us so that we can further assist you. We are always happy to help.
Thank you for visiting 2CarPros.com.
Kindest regards,
Renee
Admin
Jan 11, 2017 at 10:56 AM
