Hello, here's the cylinder layout for the vehicle. Are you getting a p0305? There is a Technical Service Bulletin on cylinder misfire codes due to carbon build up on the top of the valves. So, if a new spark plug and ignition coil don't fix the issue, you may have to look into a compression issue. Excessive carbon on top of the valves causes them to not close all the way causing a compression issue. it will be more noticeable on cold start up. With the use of Direct injection fuel systems now, most dealerships offer a valve cleaning service.
https://www.2carpros.com/articles/engine-misfires-or-runs-rough
Jan 10, 2023 at 10:39 AM
