DO NOT POWER IT OUT!
The plug is seizing to the cylinder head (usually from the heat of combustion).
Saturate the plug area where it enters the cylinder head with a good quality spray penetrate. BUT, DO NOT POWER IT OUT! If it remains difficult to remove, allow a shop to do it, but warn them (ahead of time) that the plugs are stuck in the cylinder head.
This is one recommended method you may be able to do yourself.
Apply a good penetrate like Deep Creep and run the engine up to full temperature before trying to unscrew the plug. The aluminum cylinder head will expand more than the steel body of the spark plug. If you're lucky, the plug may come out without significant damage to the threads in the cylinder head.
Jul 24, 2014 at 6:37 PM
