Spark plug adapter removal
2002 MAZDA 626
165,000 MILES • 2.5L • 6 CYL • 2WD • AUTOMATIC
JERDOG63
  • 33 POSTS
I installed spark plug adapter because of leaking oil and now I can't remove adapter.Is there any way to remove these adapters?
Aug 12, 2020 at 1:36 AM
Good morning,
Was this a self tapping or a straight bolt in replacement?
Did you use any thread sealer when you installed it?
Aug 12, 2020 at 4:18 AM
JERDOG63
  • 33 POSTS
Hey Roy! Yes this was straight bolt in adapter.No thread sealer.
Aug 12, 2020 at 9:08 AM
Okay, thanks.
Then it should come out with the same effort from installing.
Did you install it? Was there any issue installing it?
Aug 12, 2020 at 9:12 AM
JERDOG63
  • 33 POSTS
It doesn't come out with the spark plug.
Aug 12, 2020 at 9:21 AM
It will not.
The plug should come out then the adapter can be removed. You need a socket that fits the adapter to remove it.
Aug 12, 2020 at 9:25 AM
JERDOG63
  • 33 POSTS
I did try that but there is no socket bigger than a 5/8 that will fit down the port.It was suggested by a rookie that I try putting a strong epoxy to the end of an old spark plug and try inserting it.I wanted your input first.
Aug 12, 2020 at 10:06 AM
Can you post me some pictures of what you see?
Why did you use the adapter and why are you removing it?
Aug 12, 2020 at 10:10 AM
JERDOG63
  • 33 POSTS
I was getting oil on my plugs from the valve cover gaskets leaking ,causing them to misfire,so I temporarily installed adapter to compensate for the misfire until I could change the valve cover gaskets.Now that I have changed gaskets,I wanted to remove the adapter,as I have new plugs and new valve cover gaskets.I will send pics as soon as I get to the car.
Aug 12, 2020 at 10:00 PM
Sounds good. I will be watching for the pictures.
Aug 13, 2020 at 3:48 AM
JERDOG63
  • 33 POSTS
This is the adapter:
Aug 14, 2020 at 11:14 AM
JERDOG63
  • 33 POSTS
I hope you can see this.
Aug 14, 2020 at 11:15 AM
You could try using a thread sealer on the spark plug to the adapter and let it sit for a few hours and see if it will come loose.
Aug 14, 2020 at 11:17 AM
JERDOG63
  • 33 POSTS
I will try that.Thanks a million!
Aug 14, 2020 at 4:47 PM
You are welcome.
Always glad to help.
Aug 14, 2020 at 5:01 PM
