Engine shaking after replacing the spark plugs
2012 NISSAN VERSA
120,000 MILES • 2WD
SWEET HONEY
I changed my spark plugs and after I was done when I went to start it the engine started shaking and sounding like it wanted to shut off. Is it possible that I have the wrong spark plugs or could it be something else.
Aug 3, 2021 at 2:46 AM
Good morning,
I would remove them again and make sure the gaps are correct. Sometimes you get spark plugs and the gap is not there. It is non adjustable but there needs to be some clearance.
https://www.2carpros.com/articles/how-to-change-spark-plugs
Another possibility is the boots on the end of the coils. Inspect them and look for any white marks on the boots. If you see that, the boots are leaking electricity and need to be replaced. You can just get the boots without buying the entire coil.
Aug 3, 2021 at 3:15 AM
