The spare tire should have the same outside diameter size as what is on the car. You should never mix sizes. You also mentioned wheel size. A larger wheel can be used as long as the tire has a lower sidewall profile which again, has the same outside diameter as the tires on the vehicle.
I hope this helps. If I misunderstood your question, please let me know.
Nov 19, 2018 at 6:43 PM
