That's the important part of a disc brake pad. Is there a chance you simply hit it on the road and it came from a different car? These linings have been known to rust off their metal backing plates, but as soon as that happens, you would observe the brake pedal goes further to the floor the next two or three times you press it. With enough pedal strokes, that brake will self-adjust, then the brake pedal will feel normal again, however, the metal backing plate will be grinding on that brake rotor. You will hear that. The grinding is going to wear that rotor down very quickly. That can lead to total loss of front or rear brakes, and in some cases can cause that wheel to lock up.
If a mechanic looks at this right away, the cost is likely to be little more than that for a normal brake job. At the mileage you listed, it's getting close to time for a brake job anyway. Also, to keep weight down, brake rotors are made so thin that they often can't be machined, like we always did in the past, and remain above the published, legal limit. Today regular, or normal brake jobs usually have to include new rotors too.
In this case, the tabs on each end indicate this IS that metal backing plate. I've never seen that part fall off as those tabs keep them in place. If I found this on the road, my first thought would be it fell off someone's load of scrap metal on the way to the recycler. Do you hear any unusual noise when braking? Any warning lights on the dash? How do the brakes feel?
Dec 4, 2025 at 2:14 PM
