The vehicle listed above has a 2.7. Is the torque converter solenoid is located on the inside or outside transmission?
Feb 19, 2023 at 6:50 PM
CERTIFIED EXPERT
The torque converter solenoid is mounted on the valve body inside the transmission. To access it, you need to drain the fluid and remove the pan.
I am using information for a 2wd model. If you have an AWD, let me know.
I attached a pic below showing the location of the solenoid.
See pic below.
Image (Click to enlarge)
Feb 19, 2023 at 11:34 PM
ANDRAE33
MEMBER
Thank you. Yes, it's a 4WD.
2008 Hyundai Tucson 2.7. If you can please send me a pic of a 4WD torque converter solenoid location model.
Feb 20, 2023 at 4:53 PM
ANDRAE33
MEMBER
2008 Hyundai Tucson 2.7 4WD
Transmission torque converter clutch solenoid just want to be for sure you understand what I'm asking. Thanks again for your help.
Feb 20, 2023 at 5:06 PM
CERTIFIED EXPERT
I looked it up for the AWD. It's the same. I reattached it below. To access it, you need to remove the transmission oil pan.
Let me know if I can help.
Feb 20, 2023 at 8:25 PM
ANDRAE33
MEMBER
Thank you very much. This was very helpful.
Feb 21, 2023 at 3:12 PM
CERTIFIED EXPERT
You are very welcome. If you can, let me know if this takes care of the problem. I'm interested in knowing.
Also, if you have questions or if I can help, let me know.
