Soft brake pedal after replacing brakes
2010 MERCURY MILAN
120,000 MILES • 2WD • AUTOMATIC
DWANE WILLBUR
I replaced all four calipers, rotors, pads, and master brake cylinder.
Then bled the brakes with little to no pressure to the pedal. What am i doing wrong?
Thanks
Mar 17, 2019 at 2:38 PM
Good evening,
You need to bleed the system with a scan tool. Once you replaced the master cylinder, air went into the ABS unit and the only way to get it out is with a scan tool to open the solenoids while you pressure bleed the system.
Air is trapped in the system.
Mar 17, 2019 at 5:11 PM
