Soft clutch, no fluid leak/clutch failed
2008 MITSUBISHI LANCER
183,000 MILES • 2.0L • 4 CYL • 2WD • MANUAL
KAOS_ENDER
I bought the car nearly a year ago the clutch was soft but shifted good (fastforward) I drive my car to go get fuel get there gas up go to leave and then bam nada the clutch does nothing. what I need to know is how to find out is it's the main clutch assembly (pressure plate throw out bearing etc? Or is it 1 of my cylinders or a blockage in the line?
How do I diagnose the issue so I can repair it?
Also any cheap reliable car parts sites would be appreciated new and used.
Jan 23, 2021 at 4:42 PM
Good morning,
Does the pedal feel normal? If it does, then the clutch assembly needs to be replaced.
https://www.2carpros.com/articles/throw-out-bearing-replacement
If not, then it could be the clutch master cylinder. The slave is part of the throwout bearing on the transmission.
https://www.2carpros.com/articles/how-to-replace-a-clutch
https://www.2carpros.com/articles/clutch-doesnt-work-sometimes-or-not-at-all
I attached a youtube video of the replacement for you.
https://www.youtube.com/watch?v=6N6b5F2ChyE&t=32s
Jan 24, 2021 at 6:02 AM
KAOS_ENDER
What clutch comes standard in it? It's a 2.0L 4 cylinder 5 speed? Price checking parts and alternative replacements.
Jan 24, 2021 at 9:28 PM
OEM parts from the dealer will be the most expensive.
We use Luk as our parts as they have a great warranty.
I attached the parts from Rock Auto below.
Jan 25, 2021 at 5:29 AM
