I'm a ASE Certified Mechanic with 7 years of experience and am having a very stubborn some issue of not being able to get a firm pedal . This car had recently had a brake hose break and had been ran dry of brake fluid . After replacing the hose that had ruptured and making sure there weren't any leaks , I bled the system from LR,RR,FR,LR both vacuum and manually , i then proceeded to connect a Scan to to bleed the ABS system , after following the procedure I then began to bleed the system the same way as before manually and by vacuum going around 4 times to each caliper and to no luck the pedal still will sink to the floor and build pressure after a few pumps but then loose the pressure after releasing the pedal and pushing it again after about 2- 4 seconds . Before the brake hose had ruptured , the vehicle had a very firm pedal and did not require much for to stop it , which led me to believe the master cylinder and other calipers/brake hoses are completely fine and that I'm just dealing with stubborn air trapped in the system . This is a first for me and need to find out what is the best method to bleed stubborn air out of the system.
Feb 10, 2020 at 12:17 AM
