Smoking when I turn on the heat
2005 DODGE CARAVAN
340,000 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
JIM HEFFINGER
Last fall my car was smoking and a mechanic said my intake manifold was leaking. The car never overheated. When I stopped using the heater, the smoking stopped. It did not smoke all summer. Today I used the heater and it started to smoke again.
Nov 12, 2019 at 5:55 PM
Hi:
Can you tell me where you are seeing smoke? Is it under the hood or in the vehicle?
The idea that it only happens with the heat on is a bit confusing because the coolant runs through the system regardless if the heat is on or off.
Nov 12, 2019 at 8:33 PM
JIM HEFFINGER
I smell it in the car, but the smoke is coming out from under the hood on the drivers' side.
Nov 13, 2019 at 1:53 AM
Hi Jim:
Then I suspect it is one of the heater core hoses. The best thing to do is pressurize the system when it's cold and then check to see if you can find the leak. You will need a cooling system pressure tester. Most parts stores will lend / rent one to you. I will provide directions for you to help do this test, locate a leak, and if you look at the attached picture, it shows all the heater core hoses which are located on the driver's side under the hood.
https://www.2carpros.com/articles/coolant-leak-symptoms
https://www.2carpros.com/articles/car-is-leaking-coolant
https://www.2carpros.com/articles/radiator-pressure-test
Just to help you understand. Engine coolant is circulated through the heater hoses to the heater core at all times. As the coolant flows through the heater core, heat is removed from the engine and is transferred to the heater core tubes and fins. Air directed through the heater core picks up the heat from the heater core fins. The blend-air door(s) allows control of the heater output air temperature by regulating the amount of air flowing through the heater core.
Based on that, if the heater core or one of the hoses is leaking, it is always leaking and not just when the heat is used. The blend air door is inside the vehicle and is nothing more than a plastic flap that either allows air to pass the heater core or not. That is why I am confused as to why you only see steam and smell coolant when using the heater.
Let me know what you find.
Nov 13, 2019 at 6:40 PM
JIM HEFFINGER
I tested the car yesterday with a heater off and drove it around it did not smoke. but I opened up the hood and I can see coolant coming from around the intake manifold. so it is leaking without returning the heat on. your explanation was very helpful and it looks like the intake manifold gasket is the culprit. My car has 350,000 miles on it runs good but I'm not sure it is worth fixing the intake manifold gasket. I'm not sure what that would cost. I do appreciate your help!
Nov 14, 2019 at 10:22 AM
Hi:
You are very welcome. Here is what I suggest. If the van runs good and is still in good condition, think of the cost of replacing it and then compare it to the repair. This is something you can do at home if you want. You need some basic tools, some time, and a little mechanical ability.
As far as cost, honestly the gaskets are under 20 bucks if you do it yourself. Other than that, you need a small amount of RTV and coolant.
Labor for the part shows 2.9 hours, so multiply that by the shop's hourly rate. As far as the parts, they will mark them up, so I can't answer what they will do with that.
If you want to try it yourself, I suspect you can do it for under 50 to 100 dollars. Here are the directions for doing it, and the attached pictures correlate with the directions.. Take a look through them and see if you feel comfortable doing it. If you do, I can help from here if you run into trouble.
______________________________
2005 Dodge or Ram Truck Grand Caravan V6-3.8L VIN L
Lower Intake Manifold
Vehicle Engine, Cooling and Exhaust Engine Intake Manifold Service and Repair Procedures Lower Intake Manifold
LOWER INTAKE MANIFOLD
REMOVAL- LOWER INTAKE MANIFOLD
1. Perform fuel system pressure release procedure (before attempting any repairs).
2. Drain the cooling system.
3. Remove the upper intake manifold.
4. Remove the fuel line.
Fig.125
pic 1
5. Remove ignition coil and bracket (Fig. 125).
Fig.126
pic 2
6. Disconnect heater supply hose and engine coolant temperature sensor (Fig. 126).
7. Disconnect the fuel injector wire harness.
8. Remove the fuel injectors and rail assembly (Fig. 125).
9. Remove radiator upper hose.
10. Remove the intake manifold bolts.
Fig.127
pic 3
11. Remove lower intake manifold (Fig. 127).
WARNING: INTAKE MANIFOLD GASKET IS MADE OF VERY THIN METAL AND MAY CAUSE PERSONAL INJURY, HANDLE WITH CARE.
12. Remove intake manifold seal retainers screws (Fig. 127). Remove intake manifold gasket.
13. Inspect and clean manifold.
CLEANING
1. Discard gasket(s).
2. Clean all sealing surfaces.
INSPECTION
Check for:
- Damage and cracks of each section.
- Clogged water passages in end cross-overs (if equipped).
- Check for cylinder head mounting surface distortion using a straightedge and thickness gauge.
INSTALLATION - LOWER INTAKE MANIFOLD
Fig.128
pic 4
1. Place a bead (approximately 1/4 inch diameter) of Mopar Engine RTV GEN II onto each of the four manifold to cylinder head gasket corners (Fig. 128).
2. Carefully install the new intake manifold gasket (Fig. 127). Tighten end seal retainer screws to 12 Nm (105 in. lbs.).
Fig.129
pic 5
3. Install lower intake manifold (Fig. 127). Install the bolts and torque to 1 Nm (10 in. lbs.). Then torque bolts to 22 Nm (200 in. lbs.) in sequence shown in (Fig. 129). Then torque again to 22 Nm (200 in. lbs.). After intake manifold is in place, inspect to make sure seals are in place.
4. Install the fuel injectors and rail assembly.
5. Connect fuel injector electrical harness.
6. Connect the engine coolant temperature sensor (Fig. 126).
7. Connect the heater supply (Fig. 126) and radiator upper hoses to manifold.
8. Connect the fuel line.
9. Install the upper intake manifold.
10. Connect negative battery cable.
11. Fill the cooling system.
_______________________________________________
Let me know what you decide or if you have questions.
Nov 14, 2019 at 8:52 PM
Hi:
Fig.125
pic 1
Fig.126
pic 2
Fig.127
pic 3
CLEANING
INSPECTION
Check for:
Fig.128
pic 4
Fig.129
pic 5
Nov 14, 2019 at 8:53 PM
