When i press on the gas pedal smoke comes out the engine from under the drivers seat
1996 DAEWOO RACER
174,000 MILES • 1.6L • 4 CYL • FWD • MANUAL
MJAZ
  • 4 POSTS
Hello, The car smokes when i press the gas pedal. the smoke comes out of the engine and from under my seat, it is a white smoke and smells like fuel. when the gear is in neutral it does not smoke, only when i press the gas pedal. what could be the problem? i do not want to be fooled by greedy mechanics in my country.
Oct 7, 2016 at 9:14 AM
That is a good one, do you have holes in the floorboard? Never heard of smoke coming out of the side of the car from the engine?
Oct 10, 2016 at 10:10 PM
MJAZ
  • 4 POSTS
Yes, I Have holes in the floorboard , think that's why its coming to the chamber , but the Car Recently Started smoking heavily "White Smoke" when i only push the gas pedal, but when it's in Neutral Nothing happens, the smoke is coming out from under the hood not the tailpipe
Oct 14, 2016 at 2:16 AM
MJAZ
  • 4 POSTS
Also, I Recently Showed it to a Mechanic Nearby, He told me the smoke is bluish and Need an Engine Replacement but it's clearly Not, and i tested the Oil and its still the same, I've Been told that it might be the Head gasket, Also the Car Torque is Normal , not Heavy or Light
Oct 14, 2016 at 2:20 AM
MJAZ
  • 4 POSTS
and Sorry i Forgot to Mention that the Car Doesn't Overheat.
Oct 14, 2016 at 2:21 AM
Yes it does sound like the head gasket is blown, here is a guide that you can follow to confirm the head gasket problem..
Please let us know what you find so it will help others.
Best, Ken
Oct 14, 2016 at 9:27 AM
