Hello, sounds like he didn't do something right, and did he say why you needed new lifters at 88,000 miles? Was the engine making a lot of higher pitched ticking noises? If it's smoking then oil is leaking on the exhaust somewhere, most likely the valve cover gasket if he was messing around with the lifters. I would bring it back and tell them you want your money back and take it to a different shop, you shouldn't need lifters at such low mileage.
If the check engine light is on there is a code stored in the engine computer, meaning there is something wrong. He may have left something unplugged while doing the work.
Here is the correct oil type and capacity if there were any noises from the top of the engine. It may have had the wrong engine oil in it to begin with. Most quick lube places throw whatever oil they have in the vehicles that come in.
Pages 2 to 4 are some safety Recalls for your vehicle as well. The dealership should take care of these for free in most situations.
https://www.2carpros.com/articles/engine-is-leaking-oil
https://www.2carpros.com/articles/replace-valve-cover-gasket
Oct 15, 2022 at 10:24 AM
