My truck failed the California smog test. Passed the visual and functional portion and there are no codes showing. On the smog inspection report it is high emitter profile. I must take it to a Star Station The emission test HC (PPM) results:
15mph RPM 1404 Max 62 Ave 36 Meas 89
25mph rpm 1343 Max38 Ave21 Meas 73
CO (%) results:
15mph Max 0.45 Ave 0.4 Meas19
25mph Max 0.55 Ave 0.5 Meas 0.20
NO(PPM) results:
15 mph Max 512 Ave 147 Meas 786
25 mph 536 Ave 189 Meas 513
Results: Fail
I asked the technician what would cause it to fail, and he said he did not know. In 2022 I bought it to get smog test and at that time they said my truck was equipped with the wrong catalytic converter. I was able to get a CARB Executive Order for the catalytic converter showing it is approved for my truck. I had to go through the BAR Referee to get the documentation. Now that it is not passing the smog test, I don't know what to do. A new catalytic converter costs almost $600. I do not want to spend the money if it is not what is causing the failure. The truck is running good. It had a high idle about a month ago, but I adjusted the timing and now it is correct. I replaced the distributor cap, rotor, spark plug wires and plugs approximately 3 months ago (3,000 miles ago) I changed the oil last month and replaced the air filter. I do not know what more I should do at this point. What could I check? I have been told Catclean is a good product to put in the fuel to clean things out. I have to get my fuel down to 1/8 of a tank and my tank is almost full, so it's going to be a few days until I am able to put it in my fuel tank. Any assistance is greatly appreciated. Thank you in advance.
CO (%) results:
NO(PPM) results:
Results: Fail
Apr 19, 2024 at 2:58 PM
