Smell of Gas!
1999 OLDSMOBILE 88
31,000 MILES • V6 • AUTOMATIC
LILBROOK2
I just bought a used 1999 Oldsmobile 88 with only 31,000 miles on it. The car came from Ohio and has quite a bit of rust on the underneath. Supposedly the car belonged to a 94 year old woman that only drove to church and the grocery store. The car runs great and there are no check engine lights or anything on. When you drive the car, after you stop and get out, the smell of gas is really strong at the back of the car, or if you ride with the windows down you can smell it while driving. However, you cannot smell it inside if the windows are up. My dad checked and there are no any visible signs of anything leaking. Where is the smell coming from? With the windows down, it is strong enough to make you sick.
Mar 16, 2016 at 9:44 AM
HMAC300
  • 48,601 POSTS
It may be from evaporator canister or the gas cap could be bad. Also check for a broken vent hose to tank from gas cap area.
Mar 16, 2016 at 12:32 PM
LILBROOK2
Thank you! I just tried to have it inspected and it did not pass because they said there is a small hole in the tailpipe. Could that be where the smell is coming from?
Mar 18, 2016 at 4:08 AM
HMAC300
  • 48,601 POSTS
No the tailpipe would be carbon monoxide not gas. it is either a bad seal at tank or what I had previously mentioned.
Mar 18, 2016 at 2:13 PM
LILBROOK2
Thank you!
Mar 18, 2016 at 3:18 PM
