smell and no exeleration at all
2004 MITSUBISHI ENDEAVOR
118,921 MILES • 6 CYL • AWD • AUTOMATIC
MORGAN1144
  • 4 POSTS
The car smells like rotten eggs by the motor and through the vents when I turn the air conditioner or the heater on. when I start the car and put it in drive or reverse it does not go anywhere it putters and does not want to move it will not shift out of first gear.
May 11, 2015 at 1:35 PM
RIVERMIKERAT
  • 6,110 POSTS
It sounds like something may have made a nest in your exhaust. For the no power issue, have a shop scan it for soft and hard codes. There also might be something that crawled into the vent inlet opening at the back of the hood and died.
May 11, 2015 at 2:46 PM
MORGAN1144
  • 4 POSTS
well I found the battery swollen and leaking gases of the top. The amperage said 10 or volts
May 11, 2015 at 2:53 PM
MORGAN1144
  • 4 POSTS
not even 5 miles an hour
RIVERMIKERAT
  • 6,110 POSTS
Ok. Well you've definitely got an overcharged battery that has given up the ghost. You'll need to find out why it overcharged. It's most likely an alternator/regulator problem.
May 11, 2015 at 2:55 PM
MORGAN1144
  • 4 POSTS
K I'll check ty
May 11, 2015 at 2:58 PM
RIVERMIKERAT
  • 6,110 POSTS
You're welcome.
May 11, 2015 at 3:00 PM
