Good afternoon.
It sounds like you may need a water pump which is run by the belt.
You need to do a pressure test to verify.
https://www.2carpros.com/articles/radiator-pressure-test
Water Pump Replacement
Removal Procedure
1. Drain the cooling system.
2. Loosen the water pump pulley bolts.
3. Remove the drive belt.
4. Remove the water pump pulley bolts and pulley.
5. Remove the water pump bolts, pump and gasket.
6. Clean the water pump mating surfaces.
Jul 29, 2020 at 10:08 AM
