Almost every time I try to start my car for the first time of the day, the engine will crank once then stop. Upon the second or third attempt to start it, it will turn over and any other time I try to start it during the day there is no issue, so it's only ever present when the car sits overnight. This isn't too big of a problem considering I really only drive the car to keep the battery charged, otherwise it's parked 95% of the time.
What I've had looked at so far:
- The local Honda dealer had the car for almost a full week earlier this January and couldn't find any issues with the electrical system. The battery was replaced at this time, so it has less than 3,000 miles on it.
- I'm not experiencing what I've typically experienced when a starter is going bad, such as clicking or no crank. It does slow crank.
- The alternator isn't making any strange noises or producing any other symptoms that it's failing asides from potentially not charging the battery. Though, as recently as 5/2/20 this battery and alternator tested okay at my local auto parts store.
What's weird about all of this, if I turn on the headlights for 10-15 seconds before trying to start the car "sometimes" I am able to start it on the first attempt.
The car has about 142,000 on it and is driven maybe 500 miles a month. I don't use a battery tender (it sits in a lot, so I can't run an extension cord to it) and disconnecting the battery entirely when it's not in use is inconvenient.
Any suggestions are greatly appreciated.
May 4, 2020 at 6:51 AM
