Am having some trouble figuring out what/if there is a problem with my car. I just had two new tires put on the front end and noticed that at speed on motorway I was getting wheel wobble. I knew this was a balance issue so had the re balanced and this solved this issue. The problem i'm having now is a slight vibration through the wheel at all speeds in a straight line. The best way I can describe the feeling I get is if I was getting wheel rub on the arches which I know this isn't. Also when parked and in low suspension mode it looks as if one side at the front is slightly lower but very slight. 5mm or so. Could this be related? The air suspension all works as it should. Looking for advice as I'm looking to sell on and buy a newer model but would like to know there was no issue before I take money from someone. Any help much appreciated.
Jul 11, 2020 at 3:21 PM
