Slight rough idle when coming to a stop
2008 BMW X3
77,000 MILES • 6 CYL • 4WD • AUTOMATIC
LEX SUCKAFREE PRINGLE
Car has not been driving since 2008. it barely had gas when i got it. i put only $27.00 in the car to get home. when i come to a stop it gives a slight rough idle. what may that be?
Mar 24, 2019 at 5:10 AM
SEVAG P
  • 405 POSTS
Hello, thanks for using 2CarPros.
It seems engine needs full maintenance if its stopped more then ten years. replace spark plugs,fuel and air filter,and also engine oil with filter. erase fault codes if they are present then recheck.
Sends us feed back what happens with you.
Thank you.
Mar 24, 2019 at 6:30 AM
