Oh, that is totally different than I understood it. So in essence, you have no gears. First, confirm that both front axles are full engaged. I have seen them move enough that they were no longer attached in transmission.
If the axles are full engaged, something has either broken or is stuck in the release mode. Although it could be a slave that has jammed, it wouldn't be the clutch MC.
First, confirm there is no play in the axles. Then, you will need to remove the slave to confirm it isn't stuck in the actuated position.
Also, let me know if you place the trans in gear with the engine off if there is any resistance stopping the vehicle from moving as well as if there is any noise when you have the engine running and press and release the clutch.
If there is no resistance, I suspect it is an axle issue. However, it could be the slave has jammed in the release position. So, if the axles look good, remove the slave for inspection.
Here are directions for servicing the slave. The attached pic correlates with the directions.
5 SPEED MANUAL 02J
5 Speed Manual 02J
Clutch Release Mechanism, Servicing
1 Transmission
2 Ball stud
- 25 Nm (18 ft. lbs.)
- Lubricate with MoS2 grease
3 Input shaft oil seal
- Replacing
4 Guide sleeve
- With vulcanized O-ring
- If damaged replace guide sleeve and O-ring together
- Lubricate guide sleeve in area of release bearing with MoS2 grease
5 Retaining spring - Secure to clutch release lever
6 Bolt
- 20 Nm (15 ft. lbs.)
7 Clutch release lever
8 Release bearing
- Do not wash bearing out, only wipe
- Replace noisy bearings
- Lubricate surfaces which contact release lever with MoS2 grease
9 Bolt
10 Slave cylinder
11 Plunger
- Grease end of plunger with MoS2 grease
12 Assembly bolt
- Secures the clutch release lever when installing transmission
- Remove after transmission has been installed
Note: If the assembly bolt (Item 12) is not available, an M8 x 35 bolt can be used.
______________________
Number 10 in the picture is the slave cylinder.
Dec 2, 2019 at 4:45 PM
