Having a hard time removing the master cylinder?
2004 SATURN ION
200,000 MILES • 2.2L • 4 CYL • 2WD • MANUAL
LUIS7160
  • 4 POSTS
Having a hard time to extract the slave or master cylinder out, I've tried turn it clockwise and nothing happens.
Sep 4, 2024 at 3:19 AM
You must remove the transmission of the car to replace the clutch slave cylinder, here is a video of the job being done on a similar car so you can see what I am talking about please I have including diagrams in the images below to show you how the job is done on your car.
https://youtu.be/6N6b5F2ChyE?si=XfnVpmEL4nFAQyVr
Sep 4, 2024 at 11:12 AM
LUIS7160
  • 4 POSTS
I have replaced the slave cylinder, but I have no pressure at all is a Saturn ion 2004, Pedal goes to the bottom and stays there.
Sep 4, 2024 at 1:12 PM
LUIS7160
  • 4 POSTS
That's the slave cylinder.
Sep 4, 2024 at 1:15 PM
That's the clutch master cylinder. It should self-bleed, I would make sure it is full of fluid and then pump it about 50 times you should get a good clutch pedal. Let me know.
Sep 5, 2024 at 8:02 AM
LUIS7160
  • 4 POSTS
I just replaced the slave cylinder but still no pressure at all, it could be bubbles? How do I purge it? Or could it be another problem?
Sep 5, 2024 at 8:28 AM (Merged)
