Skreem car alarm, can I bypass it?
2004 CHRYSLER CROSSFIRE
20,000 MILES • 3.2L • 6 CYL • 2WD • AUTOMATIC
BMAN1G
  • 48 POSTS
is there any way to bypass the Skreem to start my car?
Oct 8, 2023 at 11:47 PM
MONSTERTRUCKDADDY
  • 31 POSTS
There are services out there that claim to be able to delete the immobilizer. I haven't used this one in particular but have done similar on other vehicles. Obviously do your own checks before sending your ECU and money anywhere.
https://www.precisionecu.com/products/2004-2008-chrysler-crossfire-me2-8-immobilizer-skreem-delete-plug-n-drive?_pos=1&_sid=419f76736&_ss=r
Oct 9, 2023 at 6:20 AM
BMAN1G
  • 48 POSTS
What I'm asking is there a way to drill into my ignition and start my car?
Oct 9, 2023 at 6:54 AM
STEVE W.
  • 15,113 POSTS
No there is no way to drill it and start it. It isn't just a mechanical switch that is needed on modern vehicles, they also need the electronic signal from the transponder in the key to tell the electronics in the immobilizer system that you are using a valid key. Both the key to physically turn the switch and the electronic validation are needed at the same time.
Oct 9, 2023 at 10:47 AM
BMAN1G
  • 48 POSTS
So, what you're saying is my car is basically a nice looking paper weight.
Oct 9, 2023 at 11:44 AM
STEVE W.
  • 15,113 POSTS
At the moment it is. However, if you contact a mobile locksmith, they can usually make you a working key provided you show proof of ownership. They will check the paperwork and usually contact the manufacturers and give them the VIN. Then they are told the key and code used to cut the key. Then once they have the working mechanical key, they will program it into the security system, and you have a working vehicle again.
Oct 10, 2023 at 5:10 AM
BMAN1G
  • 48 POSTS
really even with a start and shut down right away twice until i reset the batter a new programmed key will make the car drivable again.
Oct 10, 2023 at 7:51 PM
BMAN1G
  • 48 POSTS
It's my car and I have the title.
Oct 10, 2023 at 7:54 PM
STEVE W.
  • 15,113 POSTS
Yes, a good key will make it run. The start and shut off means it's a runner but it isn't seeing the proper key.
Oct 10, 2023 at 9:14 PM
BMAN1G
  • 48 POSTS
Okay, thanks.
Oct 10, 2023 at 10:12 PM
STEVE W. is one of our best! Use 2CarPros anytime, we are here to help. Please tell a friend.
Oct 12, 2023 at 11:45 AM
BMAN1G
  • 48 POSTS
Car came back on its own.
Oct 15, 2023 at 3:33 AM
STEVE W.
  • 15,113 POSTS
Thanks for the update, not sure I would trust it though.
Oct 15, 2023 at 8:54 PM
BMAN1G
  • 48 POSTS
I feel the same way but she's running great.
Oct 21, 2023 at 2:59 AM
