2004 Skoda Fabia WRONG PETROL
2004 SKODA FABIA
JDRY
Engine Mechanical problem
2004 Skoda Fabia Automatic
HELP i have put £7 of petrol in my skoda fabia vrs tdi 1.9 car then the petrol station advised me to top up with diesel (£31) drove it home for about 10 miles and now it doesn't start. Have been advised to get my engine drained but will i have created long term damage and what would you advise ?
Dec 7, 2009 at 2:16 PM
MHPAUTOS
  • 31,937 POSTS
Hi there, is this a petrol or diesel engine?
Mark
Dec 7, 2009 at 3:25 PM
JDRY
it is a diesel engine
Dec 8, 2009 at 11:31 AM
MHPAUTOS
  • 31,937 POSTS
You will need to have the tank flushed and change the fuel filter, bleed the system to flush the fuel lines,l diesel is also the lubricant for the injectors and pump, petrol in the system will break down the lubrication ability and also cause possible damage to the engine if it is run with petrol in the system, as far as long term damage goes, this is a bit hard to say, this will depend on how much fuel was added, normally you should be ok, but get the system cleaned and try it out,
Mark
Dec 8, 2009 at 3:55 PM
