My car has a bad skip in it when I take off. what is the best way to clean the injectors?
Oct 23, 2016 at 5:16 AM
WRENCHTECH
CERTIFIED EXPERT
Injectors have to be chemically pressure cleaned and even then, they do not always come clean. Many shops have system that will have the engine run on a chemical out of a container. They can also be removed and sent out. Most of the time you are better off just isolating the bad one and replacing it.
Oct 23, 2016 at 6:02 AM
WILLIAM TIPPER
MEMBER
Thank you, I will have this done.
Oct 23, 2016 at 6:12 AM
SATURNTECH9
CERTIFIED EXPERT
You could even have a ignition issue. I would say that is probably more likely. Have you checked for codes in the computer yet?
