I have a sinking brake pedal. I've replaced the master cylinder, ABS pump, wheel cylinders, drums, shoes, rotors and pads. New ca pliers on front a d new lines. I have a sinking pedal. The brakes engage but as the pedal sinks the obviously lose their braking power. I do have. lSPV for the rear that I have not changed also there's a combo valve (booster mounted) that I have not changed either. There are no leaks. The brakes engage almost immediately when pedal is depressed. I had the rear jack up, tires off and in drive I notice the rear are receiving full power. Upon Inspection taking the drum off. I can see like chatter marks on shoes. That's what I'm feeling when driving the truck. The whole truck shakes like the rears are just barely biting on the shoes enough to chatter (if you will) I'm stumped at this point. I have good fluid with no bubbles to each wheel. The picture included is the master/booster assembly. The bleeder screw pictured I am not getting good fluid from. But again I am to the wheels.
Oct 9, 2019 at 6:41 AM
