Feel like I have a little slack or softer clutch than normal and the rubber bushing inside the tail end of transmission is extended outward that ties to drive shaft. Also, I noticed a black hose with a metal tube with a bracket attached in which is to be bolted or held by a clip and want to know if you're familiar with this and could tell me what's its use? Found it running on top of transmission mission above rear end.
Jan 24, 2022 at 3:12 PM
