Fuse panel location picture of the flasher relay
2001 JEEP CHEROKEE
200,000 MILES
RENEE AUSBUN
Would like to see a picture of the flasher relay panel.
Oct 27, 2019 at 9:05 AM
Here is a guide to help you check the fuse and the fuse panel with locations as well:
and
https://www.2carpros.com/articles/turn-signals-not-working-blinker
Oct 28, 2019 at 1:50 PM
DJHARTZ1
Where can I get a printout of the fuse box control panel please I love this site :)
Aug 4, 2020 at 5:55 PM (Merged)
JESHEARER
  • 9 POSTS
should be but there not, GREAT QUESTION!! the repair manuals don't even have them. djhartz1 did you get one if so where?
BMRFIXIT
  • 19,053 POSTS
Fuse box /power distribution center. Click on the images below to enlarge them:
Here is a guide and more diagrams (below) to help you get the job done and fix the problem.
and
Please let us know what you find.
JANDREWS
I would like a diagram of some sort to tell me what fuses go to what.
Aug 4, 2020 at 5:56 PM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
interior fuse block legend is attaced
MICHELLENTODD
Electrical problem
1998 Jeep Cherokee 6 cyl Four Wheel Drive Automatic 150k miles
Both of my brake lights are out, I assume it's the fuse, but I don't have the manual. I need to know which fuse. Thanks
Check fuse no.22 if okay and there's power at the pink and dark blue -adjust or replace the brake switch
CHOCTAW
The factory installed Tow package (Class 111 Hitch) on my 1998 Jeep Cherokee Sport, 6cylinder engine does not work. Fuse checks good but cannot locate the the circuit breaker located near the fuse panel because I can't find the ID number forthis item. Local Jeep Dealers cannot help!!!!!!!
JAY1970
Have you found out the answer to your problem. I recently bought a used 1996 and I have running lights at the rear connection, but no turn signals or brake lights. Thank you.
CHOCTAW
Cannot find location of Circuit Breaker for the towing function. Have looked in" Mitchells" used by Repair Shops. No Luck and No tail, brake, or turn lights either. Good luck!!!!
JAY1970
I have a 96 Cherokee Sport. Behind the spare tire, behind the trim panel is the wiring and the three relays and circuit breaker for my tow package option. Simple test for the circuit breaker is either a test light or DVM to test for 12vdc (ground one lead, touch other lead to both sides of circuit breaker). All three of my relays were internally rusted. Probably from condensation over time. Napa has the relay for under 12 dollars each. My Jeep had relay part number AR634. Check Napaonline.com for correct relay for your year and model Jeep.
Good Luck!
CHOCTAW
Jay Thanks a lot. Just found out about the rear panel from a Guy last week,
YANKEEFRANK
  • 13 POSTS
I remove a small black relay instead of the red one that I needed...Now I do not know which slot it goes into...
Aug 4, 2020 at 5:57 PM (Merged)
JDL
  • 16,098 POSTS
Here is a guide to help you check the fuses and the the fuse panel location and diagrams below.
Check out the diagrams (Below). Please let us know what you find.
YANKEEFRANK
  • 13 POSTS
Yes it helps a bit...however, the diagram you provided is correct to a point...instead of being the horn relay, I have a blue relay (Chrysler #56007348) that is the dual flasher (which I assume does both hazard AND turn signals)
Regards,
Yankeefrank
JDL
  • 16,098 POSTS
Hi, which Cherokee is it, sport--limited--or what? I would think they would be the same? I'll take another look.
JDL
  • 16,098 POSTS
Yes, 93--94, the horn relay is correct. 95--the flasher is in that spot, and the horn relay is in top left empty spot, diagram, no. 5 spot.
I just didn't read far enough in the info.
YANKEEFRANK
  • 13 POSTS
Replaced the relay in it's correct spot, still don't know why turn signals don't work..
JDL
  • 16,098 POSTS
Did you check the fuses? Did you check voltage at fuse circuits. Usually the turn fuse circuit goes hot with the key on. The flasher fuse circuit should be hot all the time.
It's possible you will have to check the multifunction switch? If so, make sure you disarm the air bag before working on steering column.
YANKEEFRANK
  • 13 POSTS
Going by your drawing, there is NO fuse in number 8 slot...never been one as there is only 1 contact in the slot. Hazards work, tried a new relay didn't help. Have power in one slot where relay goes nothing in others when turn signal is in left/right position. Everything points to multifunction switch. Just don't understand why it happened all of a sudden.
JDL
  • 16,098 POSTS
I'll double-check the diagram.
YANKEEFRANK
  • 13 POSTS
I know now that the Sport wiring diagram is different than a regular Jeep. The hazards work, the flash to pass works and the wipers work. I tried a new flasher (hazards/signals) and still didn't work. I have tested and removed for inspection all of the fuses. The horn, turn signals and rear window heater relays are on a block under the drivers knees right of the steering wheel column. Any idea?
JDL
  • 16,098 POSTS
Our database says fuse block under left side of dash. If our database is wrong about fuse block location and the wiring diagrams are wrong, I'm not sure how to help?
It does show relay block to the right of steering column. I'm not giving up yet.
YANKEEFRANK
  • 13 POSTS
Fuse block is in the normal spot, above left foot of driver...I wonder if there's any difference if the Jeep was made in Canada...(just wondering).
JDL
  • 16,098 POSTS
In the fuse block to the left, is there a fuse 8--20 amp?
As far as your other question, I'm not sure.
YANKEEFRANK
  • 13 POSTS
Nothing is slot 8....never had one...
JDL
  • 16,098 POSTS
Our database shows a fuse 8 in left fuse box. Either our database is wrong or I'm looking in the wrong place? I've looked at other databases, same fuse 8--20amp.
All I can do is hope the wiring colors are correct from flasher to multifunction switch for turn signals. Then look under the dash for proper wire color going into steering column. Should be multiwire electrical connector where wires go into steering column, check voltage on that wire, key on, turn switch on. If no voltage backtrack the wire.
I'll let you know if I find more info.
YANKEEFRANK
  • 13 POSTS
That's my next plan, tracing the wires back from the flasher
JDL
  • 16,098 POSTS
Just to add, this diagram says it is for 95 jeep Cherokee sport 4.0L.
YANKEEFRANK
  • 13 POSTS
I agre...everything I've seen says that's the fuse block, but not the one I have. I can send you a photo if I can have your email address, or if you're on Facebook....Thanks for your help.....
YANKEEFRANK
  • 13 POSTS
Besides....stop and think about it, if the flasher relay is under the dash next to the steering column, WHY would there be another flasher in the fuse block?..I see that I can add an image...I'll send a photo of the fuse block tomorrow. ..
JDL
  • 16,098 POSTS
Nothing against anybody, but, I don't give out my email address. Not on facebook.
If you can save image on your desk top, is there an "add image" link at the bottom of your post. You can add image that way.
Or you can use an image host to add image on your post. I'm not an expert at any of this computer stuff.
I doubt if picture will help me, at the moment, I'm lost.
I don't suppose you have an owners manual for your vehicle? The owners manual should give you picture of fuse block and tell what fuse does what.
YANKEEFRANK
  • 13 POSTS
I see where I can add an image, I'll try to send one tomorrow. ..as for the owners manual, it hasn't been much help. It also says 20amp fuse in slot 8, but since I never removed one there's never been one..
JDL
  • 16,098 POSTS
In one of your posts, didn't you say only one hot terminal at flasher? My thinking is, should be two hot terminals with key on, one hot terminal with key off.
How many pins on flasher? Are there pin numbers? Even with one hot pin, using a jumper, you should be able to check hazard and turn, they just won't flash, should lite-up.
If turn signals will lite, one side then the other, then I think problem is before the flasher. If they won't lite up, then I think the problem is in the steering column, wiring or multifunction switch.
YANKEEFRANK
  • 13 POSTS
I've attached a photo of the fuse block. .as you can see there is no fuse in #8....
JDL
  • 16,098 POSTS
Hey, I believe you. I did try to look at picture, it just showed loading sign, that little revolving circle, no picture.
If you try my testing post, that should tell you something? I won't be able to find proper wiring for this.
YANKEEFRANK
  • 13 POSTS
Testing at the flasher is my next step.....
JDL
  • 16,098 POSTS
If your worried about using jumper wire, you can use inline fuse on the wire then hopefully if anything is shorted it will just pop the fuse.
