Hi.
Does anything happen when you turn them on? Do the hazard lights work?
I attached a pic below showing power to the flasher and then to the signal switch/hazard switch. First, check to make sure the fuses are good. If they are, make sure there is power to and from them.
Here is a link that you may find helpful:
If the fuses are good, the next thing is the flasher relay.
Let me know what you find and if anything happens when you turn the signals or flasher on.
See pics below.
May 4, 2023 at 7:31 PM
