My vehicle drains a new battery in about two weeks. The test with my multi-meter gives me a variety of amp readings from .04 to .39. These flash slowly in sequence one after the other and when it reaches .39 it starts again but with new numbers in the sequence. I tested the multi-meter with a 12 volt bulb and got a constant reading of amp load so the meter is functioning correctly. I tried pulling fuses but the current draw remains. During this process I accidentally hit the turn signal switch and the signal light came on. The signals work this way front and back and on both sides the way they should. However, the ignition key was off at the time. The ignition key works easily and starts and stops the engine but the signals should not work with the key off. What's your take on this dilemma?
Aug 6, 2019 at 8:34 PM
