My drivers side signal light flashes rapidly and the drivers side back up light does not work. please help.
Mar 3, 2018 at 3:53 PM
HARRY P
CERTIFIED EXPERT
The signal flashes quickly because one of the bulbs is burnt out. The system is designed to do that so you know that there is a problem. The reverse light probably also needs a bulb.
So figure out which signal bulb needs changing and I will see what instructions I can find for you.
