smart junction box ?
2009 FORD FUSION
60,000 MILES
JEFFHASKINS
  • 6 POSTS
since MOT no central locking or lock doors, tailgate button does not work and flashers very quick(both) good bulbs,fuse okay and emergency hazard work fine. please help. garage said it would cost more to diagnose than car
JEFF
Mar 4, 2021 at 7:56 AM
This sounds like the smart junction box went out which is common. here is instruction on how to change it out. Can you please shoot a quick video with your phone so we can see what's going on? that would be great. You can upload it here with your response. Check out the diagrams (below). Please let us know what happens.
Mar 5, 2021 at 7:44 PM
JEFFHASKINS
  • 6 POSTS
I will try to get new one. i have tried Clickmechanic support, but no one wants to help.
Mar 7, 2021 at 12:18 PM
We haven't heard from you for a couple of days. Has there been any progress? If possible, let us know. We are interested in knowing.
Mar 9, 2021 at 5:45 PM
JEFFHASKINS
  • 6 POSTS
hi, no progress at all even CLICKAMECHANIC cancelled on me. Now booked in to garage to get a price. many thanks for reply, let you know how it goes.
Mar 10, 2021 at 2:30 AM
No problem at all. We just like to make sure people get the answers they need. If you do have the chance, please let us know what was found. It will help others in the future.
Mar 10, 2021 at 4:50 PM
JEFFHASKINS
  • 6 POSTS
yes anything to help. JEFF
Mar 11, 2021 at 12:31 AM
Jeff,
I was just wondering if any progress has been made.
If you can, let me know.
Mar 13, 2021 at 8:04 PM
JEFFHASKINS
  • 6 POSTS
car in garage tomorrow, fingers crossed. thanks for reply, JEFF
Mar 13, 2021 at 11:39 PM
HAHNY1
  • 75 POSTS
Can I replace the smart junction box using a used one or does it have to be programmed to the car? The right front blinker quit working and all others still work. Can the smart junction box be fixed?
I switched the bulb and socket from the other side, checked all the fuses, and when I ran out of ideas took it to a mechanic and confirmed it
Mar 15, 2021 at 9:13 AM (Merged)
Here is a location and the diagram on how to change the smart junction box which go out (below) It will self initialize so you should not need to have it programmed. Please let us know if you need anything else to get the problem fixed. Cheers, Ken
DON0352
Hello Ken.
Thank you for the good information.
I have to replace my SJB on my 2006 Ford Fusion SEL.
I can't find one anywhere online.
Do companies repair them?
Or would you know of 1 that's for sale?
Thanks very much.
Mar 15, 2021 at 9:14 AM (Merged)
There are companies that rebuild them and I would just suggest performing an internet search looking for some of them because I did a quick search and found a few but one on a popular online auction site.
We don't recommend any site over the other so you do have options out there but it appears they are all re manufactured. I was not able to find any that are new.
Hopefully this information helps. The best way to find one is pull the part number off the one that is in your vehicle (there should be a tag with it on it) and just search for that number. It should pull up all that are available.
DON0352
Thanks very much for the info.
I'm going to get the part number tomorrow.
One question.
Under the steering wheel, I have to remove that panel to get to the SJB.
I took off the top by popping it. Easy.
But the bottom wouldn't budge.
Is it just a pop off also?
Didn't want to break something.
Thanks again.
I have looked and it doesn't have a process for taking this panel off. However, from what I remember there are some bolts/nuts that hold that one on.
If you want to get some pictures of it, it may help me remember exactly where they are. Thanks
RENEGADE600
I had the right front signal light stay on and got the signal failure message on the display. Read up and found it’s a faulty SJB (smart junction box). I got a used one at an auto parts recycler. After I installed it, I get door ajar messages and the car won’t shift out of park.
Mar 15, 2021 at 9:15 AM (Merged)
Good evening,
Can you post the part number from your old block and the part number from the new one? Good chance you either have the wrong one installed or the junkyard unit is no good. Here are instructions below. Check out the diagrams (Below). Please let us know what happens.
RENEGADE600
Both boxes have the same number.
6E5T-14B476-A
Thank you.
This module needs to be programmed to work correctly. I contains all the information for the car based on your VIN number. Right now, it has another VIN number in it from the donor car.
You will need to have some program it for you so everything works.
