Hello, I have the vehicle listed above in near perfect shape, had it for 11 years with almost no issues. This is the 2nd Generation 6s. Had all the recalls done in 2017 or so. The air bag light came on in 2017 and was Diagnose at the Mazda Stealership and that code was B1127 for the passenger front seat side airbag. Then in Jan 2023, I took it back again and it was B1126 for driver seat side airbag.
Now during this time frame the light would come on and I was told the connection under the seat might be loose or needed to be reconnected and once I did that the light would go off. Now it might stay off for a year or more or when the weather changed. It started in 2022 doing coming on more so that is why I took it back to get scanned again in Jan 2023 and found out it was the driver's side. After the scan the light remained off until August.
Here is why I am contacting you guys. I can't get a straight answer from neither of the Mazda Places nor actually talk to the tech who did this. One shop told me it was a common connection issue and the other is saying it needs to be repaired. My car is worth 6 grand and the 2 repairs will probably be about 2 grand and that is not worth it. Yes, I have complained a lot and got a few small answers.
So, my three questions are:
1. From reading this what do you think this is on with this 2nd Generation Mazda 6 cars air bags?
2. If the light went off for 9 months does that mean it works now and then when flashing it does not?
3. I presume a scanner will clear the codes for some time without the flashing light always on so what kind of scanner that is all around good to get without breaking the bank and that I can use in the future on other vehicles I may get is good to buy? I just want to eliminate the flashing air bag light as I don't see myself repairing those air bags.
Your link in the YouTube video is dead as that is where I found you at. I can send over the invoices on the next reply and I don't mind donating as well after were done. Thanks.
Randall
Randall
Oct 26, 2023 at 2:46 AM
