Side engine mount torque specs needed?
2011 HYUNDAI ACCENT
207,000 MILES • 4 CYL • 2WD • AUTOMATIC
DAMIANKROPP
I have an engine mount that seems to let my engine rock back and forth and i don't know the torque specs of it looking at the car it's on the left side.
Nov 27, 2024 at 1:15 PM
Yep, when those engine mounts go out the engine will move excessively, here is how to change the mount out and the torque specs as requested, make sure to use a piece of wood under the engine oil pan with a floor jack to support the engine while the repair is being done. Check out the images (below). Let us know if you need anything else.
Nov 28, 2024 at 12:08 PM
DAMIANKROPP
Thank you, my friend, I will check that out tomorrow and will do that with the wood. thanks for your professionalism.
Nov 28, 2024 at 2:29 PM
You are welcome, let us know if you need anything else.
Nov 29, 2024 at 10:22 AM
