Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Honda
Odyssey
Engine
Symptoms
Stall While Driving
Shutting off while driving
2002 HONDA ODYSSEY
190,000 MILES • 6 CYL • 2WD • AUTOMATIC
KELLER132
MEMBER
1 POST
FOLLOW
Whenever I drive vehicle loses power then shut off. After 5 to 10 minutes it started again and drive again.
Aug 27, 2019 at 11:27 PM
CERTIFIED EXPERT
Good morning,
Does the transmission shift okay?
Can you rev up the engine in neutral?
https://www.2carpros.com/articles/engine-has-low-power-output
I would start by checking the fuel pressure. Low pressure from a failing fuel pump will cause this issue.
Aug 28, 2019 at 2:21 AM
