Hello GOMEZJEANESSA,
Is this vehicle completely stock?
Also is it an RS or IROC-Z?
If so, it's possible it is your Idle Air Control Valve. It is located on the passenger side of the throttle body under the air cleaner. I will add a picture to aid in locating it.
Sometimes they get gummed up and you can clean them but more than likely it will need to be replaced.
I would inspect the wiring just to make sure there are no issues there.
This article will help aid you in doing that:
This article will give you an idea of its operation but does not look anything close to the one you will find on your Camaro. This is more just for you information. I think understanding how a component operates is a big leap in diagnosis.
Here is the article:
https://www.2carpros.com/articles/how-a-idle-air-control-valve-works
Hope this helps. Let me know how it goes.
Thank you,
Brendon
Apr 16, 2023 at 11:18 AM
