If the oil filter was replaced, remove it and replace it with a different one. As far as the oil level is concerned, if it doesn't circulate, it will indicate it's too high because it hasn't filled the oil filter. When you remove the filter, see if it is full of oil or not.
At that point, we need to start it to see if the problem still exists. If the light is on, pay attention to see if there is any ticking or knocking from the engine. If there is, shut it down. We will need to check the oil pump at that point.
If you have a scan tool, see if there are diagnostic trouble codes present prior to restarting the engine and let me know what they are.
Let me know what you find.
Oct 31, 2022 at 5:32 PM
