Hello, here I'm.
I bought an ODB2 codes reader. So the situation is:
a) There are no codes set in PCM, there are no codes in memory. The vehicle's instrument checker (when you turn on the key with both buttons, trip and reset, pushed) still report error 905 and 999.
b) there is no check engine light on.
c) when it doesn't start, the RPM tachometer moves a little while cranking.
d) when it doesn't start, I don't hear the fuel pump.
Also,
e) the instrument cluster and the heater panel have been re-welded.
f) the speed sensor has been disconnected without result
g) the oxygen sensor has been disconnected and it seems get worse; it shuts off after 30/40 meters and it has more difficult to start again.
Oops.. Sorry, I forgot to tell. My vehicle has an electronic sequential LPG system mounted on. It starts with LPG in emergency mode, but doesn't start with gasoline.
I'll try the several check listed in the engine stalls articles, meanwhile any idea will be appreciate.
Thanks and have a nice day,
Francesco.
Nov 8, 2019 at 3:15 AM
