Shuddering while shifting and weird pinging rattle sound?
2012 FORD ESCAPE
111,000 MILES • 3.0L • V6 • 2WD • AUTOMATIC
TYLER CHAMBERLIN
When I push the gas pedal while coasting it rattles and it affects my acceleration. And when getting on freeway and shifting from 3 to 4 gear it jerks hard almost like its losing power and I've replaced a lot of stuff including tranny rebuild and I can't figure it out. I'm thinking it's shift solenoids and they didn't replace them like they said they did.
Apr 30, 2023 at 2:50 PM
Does the rattling sound seem to come from under the vehicle? Also, when it's heard, is that when you experience power loss? If that is the case, take a rubber mallet and tap on the exhaust system to see if you can recreate the sound. You could have a catalytic converter that has come apart internally blocking the exhaust.
Take a look at this link:
https://www.2carpros.com/articles/bad-catalytic-converter-symptoms
Next, if that isn't the case, then we need to scan the can-bus to see if there are diagnostic trouble codes stored in any of the different modules.
CAN stands for controller area network. Basically, all the different modules and computers are tied together via a few wires. This type of scan will retrieve codes regardless of the module storing them.
Here is a link that explains how it's done:
https://www.2carpros.com/articles/can-scan-controller-area-network-easy
Let me know if that is something you can do or have done.
Apr 30, 2023 at 8:04 PM
