Welcome to 2CarPros.
When you have the clutch out, inspect the flywheel. I always have them resurfaced at a minimum. If, however, there are heat marks in it, replace it. You won't get them out and it could cause a chatter when you release the clutch.
Here are the specifics on flywheel removal and replacement. The directions include torque specs. Additionally, the attached pictures correlate with these directions.
___________________
DUAL-MASS FLYWHEEL
Dual-Mass Flywheel
Special tools, testers and auxiliary items required
Counter-holder tool (3067)
Removing
Engine or transmission removed.
- Remove clutch pressure plate.
CAUTION!
To prevent damage to dual-mass flywheel when removing, bolts - B - must not be removed using an air-powered or impact wrench. Only removing bolts by hand is permitted.
- Rotate dual-mass flywheel - A - so that bolts - B - stand centered to holes - arrows -.
picture 1
- When removing bolts - B -, make sure that bolt head does not contact dual-mass flywheel
- arrows - and thereby cause damage when turning it further.
- Insert counter-holder (3067) into hole in cylinder block - B -.
picture 2
- Mark dual-mass flywheel to engine.
- Remove dual-mass flywheel.
Installing
Installation is in reverse order of removal, note the following:
- Use new bolts when securing.
- Insert counter-holder (3067) into hole in cylinder block - A -.
picture 3
Torque specification
picture 4
__________________________
Here are the directions for clutch replacement:
CONVENTIONAL CLUTCH
Conventional Clutch
Please refer to notes, refer to => [ Clutch General Repair Information ] See: Clutch, M/T > Procedures > Clutch General Repair Information.
The transmission has to be removed before working on the clutch. Refer to => [ Transmission, Removing ] See: Manual Transmission/Transaxle > Removal and Replacement > Transmission, Removing.
picture 5
1 Flywheel/dual mass flywheel
Make sure that dowel pins fit tightly.
Contact surface for clutch lining must be free of grooves, oil and grease.
Removing and installing, refer to => Engine Mechanical See: Engine > Mechanical > Cylinder Head, Valvetrain - Fastener Tightening Specifications
2 Bolt for flywheel
Always replace.
Bolt length: 22.5 mm; 60 Nm + an additional 90° 1/ 4 turn.
Bolt length: 43 mm; 60 Nm + an additional 180° 1/ 2 turn.
3 Clutch plate
Installation position: Clutch lining must make full contact with flywheel.
The marking "Getriebeseite" (if provided) faces pressure plate/transmission.
Coil springs (damper assembly) point toward pressure plate and transmission.
Centralize, refer to => [ Centralizing clutch plate and removing and installing pressure plate ]
Clutch plate diameter, refer to => [ Code Letters, Allocation, Transmission Ratios, Capacities ] See: Manual Transmission/Transaxle > Components > Code Letters, Allocation, Transmission Ratios, Capacities.
4 Pressure plate
Removing and installing, refer to => [ Centralizing clutch plate and removing and installing pressure plate ]
Check ends of diaphragm spring, refer to => [ Checking ends of diaphragm spring ]
Check spring connection and rivets, refer to => [ Checking spring connection and rivet ]
Check wire ring, refer to => [ Checking wire ring ]
5 Bolt, 22 Nm
Loosen and tighten gradually in several stages and in diagonal sequence.
6 Needle bearing
picture 6
- Loosen and tighten bolts gradually in several stages and in a diagonal sequence.
- To remove, reverse position of counter hold tool (3067) or counter hold tool (10 - 201).
Installation position of clutch plate: coil springs (damper assembly) or marking "Getriebeseite" point toward pressure plate and transmission.
- Before tightening securing bolts, clutch lining and contact surface of pressure plate must make full contact with flywheel.
picture 7
Wear up to half the thickness of the diaphragm spring is permitted.
When performing repairs, always select the correct clutch pressure plate and clutch plate by checking engine code.
picture 8
- Check spring connections - arrows A - for damage and make sure riveted fastenings - arrows B - are seated tightly.
Replace pressure plate if spring connections are broken or badly bent, or if riveted fastenings are loose.
Checking wire ring
picture 9
- Check that wire ring in pressure plate - arrow - is not damaged. Replace pressure plate if wire ring is broken.
_________________________________________
Here are the directions for removing and replacing the transmission.
Transmission, removing from vehicles with 4-cylinder engine, 01X, 6-Speed Front-wheel Drive M/T
picture 10
^ Engine support bridge 10-222 A
^ Transmission support 3282
^ Adjustment plate 3282/43
^ Torque wrench V.A.G 1331
^ Torque wrench V.A.G 1332
^ Engine/transmission jack V.A.G 1383 A
picture 11
^ Insert pad for front fender T40045
^ Grease for clutch plate splines G000100
^ Copper grease Z381351TE
Procedure
Note:
^ All cable ties which are released or cut open during removal must be installed in the same position when installing.
^ Heat insulation sleeves removed during removal of transmission must be installed in the same position when installing.
CAUTION!
^ Follow steps required when disconnecting battery.
picture 12
- With ignition switched off, disconnect battery Ground (GND) strap - arrow -.
picture 13
- Remove engine cover - arrows -.
picture 14
- Detach rubber seal from edges of wing mounting flanges.
- To avoid damaging edges of fenders with engine support bridge 10-222 A, insert wing compensation plates T40045 on both sides between fender mounting flange and body panel underneath.
picture 15
- Set up engine support bridge 10-222 A with adapters 10-222/3 on fender mounting flanges.
- Engage spindles on engine lifting eyes as illustrated.
- Take up weight of engine using spindles.
picture 16
- On vehicles equipped with auxiliary heater remove screws - arrows - securing exhaust pipe of auxiliary heater to sound insulation.
picture 17
- Loosen bolts/quick release fasteners - 1 - and - 2 - and remove front sound insulation - A -.
Note:
^ - Item 3 - and - item B - can be disregarded.
picture 18
- Remove bracket - arrow - for sound insulation.
picture 19
- Unbolt heat shield - arrow - for drive axle (right side) from transmission.
- Unbolt drive axles (left and right) from transmission flange shafts.
picture 20
Note:
^ The flexible pipe connection (de-coupling element) on the front exhaust pipe must not be bent more than 10° - otherwise it can be damaged.
- Separate exhaust system at clamp - arrow - and slide clamp to rear.
picture 21
- Remove bolt - 1 - and nut - 2 - and detach retaining bracket for front exhaust pipe.
picture 22
Cabriolet:
Note:
^ On Audi Cabriolet vehicles the following steps are required in order to remove the three bottom engine/transmission bolts:
- Unbolt torque reaction support - arrows -.
picture 23
- Remove nuts - 1 - on left and right sides, and swivel stabilizer bar - 2 - downward.
- Remove nut - 3 - on left and right engine mountings until bottom of nut is flush with end of stud - arrow -.
- Use engine support bridge 10-222 A to lift engine just enough for nuts - 3 - to make contact with bottom surface of left and right consoles.
picture 24
Continued for all vehicles:
- Remove three lower engine/transmission securing bolts - arrow -.
Cabriolet:
- Lower engine back down.
picture 25
- Detach starter from engine/transmission and secure if necessary.
Note:
^ Starter cables do not have to be disconnected.
picture 26
- Drill a hole of 10.2 mm diameter - arrow - in supporting elements of transmission support 3282.
picture 27
- To remove manual transmission 01X, set up transmission support 3282 with adjustment plate 3282/43 and place on engine/transmission jack V.A.G 1383 A.
Note:
^ The support elements 3282149 - arrows A - and 3282152 - arrows B - are shown in schematic form on the adjustment plate. The arrow on the adjustment plate points toward the direction of travel.
^ Adjustment plate can only be installed in one position.
picture 28
- Align adjustment plate parallel to transmission.
- Secure supporting elements to left side of transmission, as shown in illustration. Tighten bolt arrow - on right side to 20 Nm.
picture 29
- Secure supporting elements to right side of transmission, as shown in illustration. Tighten bolt - arrow - on left side to 20 Nm.
picture 30
- Remove bolts - 1 - and bolts - 2 -.
picture 31
- Remove nuts - arrows - and detach tunnel cross member.
- Lower transmission slightly using engine/transmission jack VAG 1383 A.
picture 32
- Disconnect electrical connector - arrow - for back-up light switch F4 and move electrical wire clear.
picture 33
- Remove connecting rod - 2 - for selector rod.
- Remove push rod - 1 - by using an 8 mm hex key when removing bolt.
picture 34
- Remove nut - arrow - and detach selector shaft lever from selector shaft.
picture 35
- Remove upper engine/transmission securing bolts - arrows 1 - and - arrows 2 -. Please note that retaining brackets for wires/lines and coolant pipe may be secured on bolts - arrows2 -(important for installation).
- If installed, remove retaining clips/cable ties together with Lambda probe wiring from transmission.
picture 36
- Remove remaining engine/transmission securing bolts - arrow A - and - arrow B -.
- Press transmission off dowel sleeves and lower carefully with engine/transmission jack VAG 1383 A just far enough to gain access to slave cylinder.
Note:
^ When lowering transmission, make sure hydraulic line to slave cylinder is not damaged.
picture 37
- Remove slave cylinder from transmission - arrow - and secure with wire; do not open line/hose system.
CAUTION!
Do not depress clutch pedal after removing slave cylinder. The slave cylinder would then be destroyed once pedal force exceeds approx. 300 N.
- Lower transmission completely with engine/transmission jack V.A.G 1383 A.
Note:
^ When lowering transmission, make sure there is sufficient clearance to drive axles.
- Before carrying out assembly work, secure transmission to assembly stand, using holding fixture VW 540.
picture 38
- If you will be installing a new transmission instead of the one removed, the transmission mounting has to be transferred to the new transmission -
Let me know if this helps or if you have other questions. Also, if yours isn't a 6 speed, let me know.
Apr 9, 2019 at 8:03 PM
