Shorted out high pressure A/C switch trying to jump it, will not start
2013 NISSAN ROGUE
130,000 MILES • 2.4L • 4 CYL • 2WD
SANDRABOUNDS
Tried jumping high pressure A/C wires and shorted them out.sparked to battery and starter went out.replaced it wit a used one. it throws code of mass flow sensor.replaced that.
Apr 19, 2020 at 1:51 AM
SANDRABOUNDS
Why does it give code of throttle body sensor?
Apr 19, 2020 at 2:03 AM
Good morning,
Let us start with the codes? Can you list the code numbers for me to see so I can help you?
Did you verify power to the high pressure switch?
I attached a wiring diagram for you to view. Verify power to the fuses with the key on. This is not a visual test, it is a power test.
Apr 19, 2020 at 5:09 AM
